Document Server and PLESK
Postby cartenca » Mon Apr 03, 2017 12:02 pm
Id' need to install DOCUMENT SERVER into a server with PLESK ONYX on.
With Community Server it seems to be possible:
"If you need to change the port for Community Server, you can do that using the -p command.
E.g.: to make your portal accessible via port 8080 you will need to use the following command:
sudo docker run -i -t -d -p 8080:80 onlyoffice/communityserver"
What about DOCUMENT SERVER?
Thaks
Carlo
cartenca
Re: Document Server and PLESK
Postby Maxim » Mon Apr 03, 2017 12:44 pm
Hello cartenca!
We DO NOT recommend you to use custom ports, 80 and 443 only for correct OnlyOffice work.
