Unable to install on Win Server 2016 Standard
Postby Wandos » Tue Mar 21, 2017 9:22 am
I'm trying to install OnlyOffice Community Server on Windows Server 2016 Standard runnig in a VM; the setup goes smoothly until I get the following error:
"The following required windows feature are not available on your system: ServerCore-FullServer"
This is weird because the OS has the full GUI enabled by default.
Wandos
Re: Unable to install on Win Server 2016 Standard
Postby Maxim » Tue Mar 21, 2017 1:07 pm
Hello Wandos!
Please specify what instruction did you use to install?
Postby Wandos » Tue Mar 21, 2017 3:02 pm
Hi Maxim,
I simply used the installer:
ONLYOFFICE_CommunityServer_Win-install.v8.9.1.340.exe
then I tried a previous release:
ONLYOFFICE_CommunityServer_Win-install.v8.7.1.290.exe
I also tried to run the installers as admin without success.
Wandos
Postby Maxim » Wed Mar 22, 2017 12:10 pm
Hello Wandos!
Thank you for your information. We will try to reproduce your issue on Windows Server 2016.
If you want the issue to be solved remotely please mail to support@onlyoffice.com
Postby abasilio » Tue Nov 14, 2017 6:08 pm
Are there any news regarding this issue?
I've faced the same problem. When installing version 3.0 in Windows 2016 I got this same error.
Then I downloaded and tried to install version 17.11 (the most recent as of now) and I got an error when installing pre-requisite Sharepoint Server 2013 Client SDK.
When looking for error details in event viewer, there is only a record stating that installation failed followed by another one stating error status 0.
And sometimes there is a success message instead of the failure one.
Thanks in advance
abasilio
Postby Maxim » Mon Nov 20, 2017 11:44 am
Hello abasilio!
Do not try to install version 3.0! It is the very old version )))
17.11.148 - please pay attention that the server must be connected to the Internet with no proxy.
