Ubuntu 14.04 Install help
Postby macwinuxit » Thu Feb 23, 2017 9:59 pm
I installed OnlyOffice by following the instructions here:
It seems to have worked, the service is running. However, all it gives me is the attached image.
No option to login, create users, or anything. Is there another component I'm missing here? I've hunted around for a bit here, but don't see anything.
Screen Shot 2017-02-23 at 3.59.15 PM.png (71.59 KiB) Viewed 1030 times
macwinuxit
Re: Ubuntu 14.04 Install help
Postby Maxim » Fri Feb 24, 2017 8:05 am
Hello macwinuxit!
You need to insatll Community Server, you have Document Server only. So you have several ways:
1 To install Community Server on another machine (there is no a chance to install Servers for linux on one machine, that's why we use Docker to use on one machine)
2 To install Community Edition
3 To install Enterprise Edition
For testing OnltOffice we recommend you to install Enterprise Edition. The license key you can get here. There is Control Panel in Enterprise Edition installed which will help you to update, to create backup, to use LDAP and so on. If you don't need this you can install Community Edition.
