Error when compiling Document Server for a local server
Postby clavth » Thu Nov 03, 2016 1:39 am
English is not my first language.
I'm trying to compile Document Server for Debian 8.*.
I'm following you guide @ http://helpcenter.onlyoffice.com/server ... -code.aspx
I have 0 error during the process, but at the end, some files are missing.
sudo -u onlyoffice "/var/www/onlyoffice/documentserver/server/tools/AllFontsGen"\
        "/usr/share/fonts"\
        "/var/www/onlyoffice/documentserver/sdkjs/common/AllFonts.js"\
        "/var/www/onlyoffice/documentserver/sdkjs/common/Images"\
        "/var/www/onlyoffice/documentserver/server/FileConverter/bin/font_selection.bin"
sudo: /var/www/onlyoffice/documentserver/server/tools/AllFontsGen: command not found
Makefile:117: recipe for target 'install' failed
make: *** [install] Error 1
Script can't find AllFontsGen, AllFonts.js and font_selection.bin.
I found the first and the second with google's help @ https://lab.nexedi.com/bk/DocumentServer
But I can't find font_selection.bin.
So ... I'm stuck.
Any help would be appreciated.
Thanks.
CLAVTH.
clavth
Re: Error when compiling Document Server for a local server
Postby Maxim » Thu Nov 03, 2016 6:30 am
There is similar problem https://github.com/ONLYOFFICE/DocumentServer/issues/37. Please pay attention to the post of our coder:
you should run not AllFontsGen directly, but by sh file
bash /usr/bin/documentserver-generate-allfonts.sh
Try this sh file!
Postby yisusflow » Wed Dec 13, 2017 3:15 am
Pudiste compilarlo ? yo estoy teniendo problemas actualmente para Ubuntu server 14
yisusflow
Postby Charith » Tue Apr 10, 2018 6:53 am
I've compiled community server on a windows server 2012 R2, using the ONLYOFFICE_CommunityServer_Win-src.v9.6.572.zip file in the following URL.
https://sourceforge.net/projects/teamla ... 6/sources/
I have followed these instructions:- https://helpcenter.onlyoffice.com/serve ... -code.aspx
The onlyoffice community server installed with no problems or errors.
But, the only thing I get is "Sorry, portal is on maintenance. It may take some time."
Could you please help me.
Charith
Postby Charith » Thu Apr 19, 2018 3:41 am
I solved the issue. It was about database connection. Thank you very much, Max, for your support. :D :D :D
Charith
Postby Maxim » Thu Apr 19, 2018 7:18 am
Hello Charith!
You are welcome! ;) :D
