Installation - Postgresql credentials
Re: Installation - Postgresql credentials
Postby Pavel.Lobashov » Thu Dec 22, 2016 1:13 pm
So I managed to create very simple and very raw Dockerfile from our instruction on `debian:latest`. And it works fine for me. I think there is some troubles with configuration of postgresql.
Try to completely remove PostgreSQL and perform a clean install
https://gist.github.com/ShockwaveNN/316 ... 64847f4b2f
Pavel.Lobashov
Postby Schroeffu » Fri Jan 06, 2017 4:07 pm
I personally have switched to the docker-version after this issue, which runs mostly fine (sometimes not that fast when clicking around, but okay so far)
If someone else expect the same issue, he should try the solutions written here, and give us a feedback :-)
all the best
Schroeffu
Postby Maxim » Mon Jan 09, 2017 11:46 am
It would be great if someone give us feedback about this issue! ;)
Postby temujeen » Fri May 05, 2017 6:51 am
all is you need - just delete /var/lib/dpkg/info/onlyoffice-documentserver.*
# rm /var/lib/dpkg/info/onlyoffice-documentserver.*
# apt -f install
all will be good :-)
temujeen
Previous
