DKIM Problem / webmin
Postby efreet » Mon Aug 15, 2016 2:34 am
I successfully installed everything following the instruction on this http://helpcenter.onlyoffice.com/server/docker/community/docker-installation.aspx link. However, I got stuck on the DKIM/Domainkeys configuration.
I am using webmin to configure my DNS and I don't know where can I find the 'Flags', 'Algorithms' and 'Protocols' which is needed when creating a public key on webmin.
Please help!
Thanks!
efreet
Re: DKIM Problem / webmin
Postby Eugenie » Mon Aug 15, 2016 2:12 pm
You need to contact your hosting provider to get this information.
Eugenie
