Connecting Community & Documents
Postby HM-Mike » Thu Aug 11, 2016 11:10 pm
How do we connect the Community and Document editor on the same server? I've seen in the forum that this isn't possible on Windows, is this the case for Linux?
Thanks,
Mike
HM-Mike
Re: Connecting Community & Documents
Postby Eugenie » Fri Aug 12, 2016 2:31 pm
In order to install ONLYOFFICE Community Server and Document Server on one server, please follow the instructions below:
Eugenie
Postby HM-Mike » Fri Aug 12, 2016 3:42 pm
How do we do it without docker?
Thanks,
Mike
HM-Mike
Postby Eugenie » Mon Aug 15, 2016 1:27 pm
You can install ONLYOFFICE Community Server and Document Server on one server only if you use Docker or Virtual images.
Eugenie
Postby HM-Mike » Mon Aug 15, 2016 1:45 pm
I followed the instructions you gave but it's not connecting to the document server. Getting an error saying OnlyOffice is not available.
HM-Mike
Postby HM-Mike » Mon Aug 15, 2016 10:26 pm
I've done some further investigations. I just couldn't get this to work for a while, then I went into trial and error mode.
1. I reinstalled the VPS with Ubuntu 15.04, updated it, generated SSL's with LetsEncrypt and then used your one-click installer.
2. After the install had completed, I checked documents and it works (using the server IP).
3. I then tried to connect using the DNS name, I checked documents and it works.
4. I moved the cert files into /app/onlyoffice/CommunityServer(DocumentServer)/data/certs
5. I tried visiting DNS name via https, it didn't work. Attached the CommunityServer container which warmed up mono and reloaded nginx, https now worked.
6. Tested documents after SSL being enabled on community server and they worked.
7. Attached document server container, restarted nginx, documents still worked via https.
8. Rebooted host server.
9. No longer able to access https, attached community container, restarted nginx, community now loads but documents no longer work.
What am I missing here? What am I breaking?
Thanks,
Mike
HM-Mike
Postby Eugenie » Wed Aug 17, 2016 2:13 pm
Eugenie
