access problem comunity server
Postby tulip » Wed Jul 27, 2016 11:12 am
Hello I have installed unloaded onlyoffice for virtualbox and when I accede to the portal it continues loading default.aspx again and again.
Thank you for his help
tulip
Re: access problem comunity server
Postby Dean » Thu Jul 28, 2016 6:40 am
Please restart nginx with:
- Login to VM with user: onlyoffice, pwd: onlyoffice;
Attach to the docker container:
sudo docker attach onlyoffice-community-server
service nginx restart
Postby tulip » Thu Jul 28, 2016 12:06 pm
Hello
Thanks for your reply
Te problem continue.
I attach instantaneous of the received message.
Also I have installed the version for windows and on having finished the installation accede to the page wizard but I do not manage to happen of there.
A greeting
tulip
Postby Eugenie » Tue Aug 09, 2016 2:01 pm
Please open Terminal on host and execute
docker ps
Check if there is document server running in the list you get
If there is no document server, execute:
docker ps -a
If document server is shown but inactive, then start it using:
docker start [documentserver_id]
If it starts successfully, please re-start nginx and open the portal. If document server does not start, please send us a screenshot you get when it starts.
Eugenie
