404 Errors
404 Errors
Postby viandante » Wed May 04, 2016 1:05 pm
Hi to all,
I have installed the windows version of community server, but when i go to http://localhost i get the page unformatted and the js console said to me that every css and js resource are not found.
Why? Solutions?
Thanks a lot!
Regards
Massimo
viandante
Re: 404 Errors
Postby Dean » Thu May 05, 2016 11:58 am
Please check the folder C:\Program Files (x86)\Ascensio System SIA\ONLYOFFICE\Data and a subfolder bundle being there. If there is no such a folder, create it, restart site & pool from IIS and try again.
Re: 404 Errors
Postby viandante » Thu May 05, 2016 12:09 pm
The subfolder does not exist...
Once created and restart sites & pool, the errors are the same:
Failed to load resource: the server responded with a status of 404 (Not Found)
http://localhost/discbundle/common/java ... 0609120758
Etc...
viandante
Re: 404 Errors
Postby viandante » Thu May 05, 2016 12:25 pm
Etc...
viandante
Re: 404 Errors
Postby Dean » Fri May 06, 2016 12:42 pm
Check also the folder:
C:\Program Files (x86)\Ascensio System SIA\ONLYOFFICE2\Data
Re: 404 Errors
Postby viandante » Fri May 06, 2016 2:08 pm
No changes...
So in the Ascensio System SIA folder now i have two folders: ONLYOFFICE and ONLYOFFICE2
Correct?
In each forlder, there is the Data folder, and in the Data folder there is a bundle folder...
But i have the same errors...
viandante
Re: 404 Errors
Postby Dean » Mon May 16, 2016 8:00 am
Please try to access server via IP, not via localhost.
Re: 404 Errors
Postby viandante » Mon May 16, 2016 8:20 am
Same errors...
No problem with linux version.
viandante
Re: 404 Errors
Postby Dean » Mon May 16, 2016 8:35 am
Did you install ONLYOFFICE as an admin?
Re: 404 Errors
Postby viandante » Mon May 16, 2016 8:49 am
Yes, i used an administrator user.
I have to use the user "administrator"?
viandante
Next
