OnlyOffice Configuration
Postby dilipe » Mon Apr 04, 2016 8:10 am
I have some question about OnlyOffice Open-Source Configuration:
- Can I use OnlyOffice and Document Server on the same server ?
- Can I use the Desktop Editors with my server ?
- How many memory (RAM) can you recommand me for 10-20 users ? on my server with simultaneous connection.
And last question, about Ascensio System, what is the turnover of Ascensio System or OnlyOffice.
Thank you for your help and sorry for my english, i'm french.
Dilipe
dilipe
Re: OnlyOffice Configuration
Postby Dean » Mon Apr 04, 2016 3:30 pm
1) Yes for using docker and no for deb-packages (talking on Linux-server)
2) Yes, for the Portal Versions starting from 8.7.1
3) We recommend to use 6 Gb or more for installing 3 components on one server.
This information is private.
Postby dilipe » Tue Apr 05, 2016 9:02 am
Thank you.
I would install Desktop Editor but I don't know what is the portal name of my server.
How can I do ?
dilipe
Postby Dean » Tue Apr 05, 2016 12:41 pm
The name of your server will be the ip-address of the server (internal or external).
Postby dilipe » Mon Apr 11, 2016 8:22 am
Yes, I have enter the ip-address of my onlyoffice server but I have an error about portal access
dilipe
Postby Dean » Mon Apr 11, 2016 8:27 am
What is the error appearing?
Postby dilipe » Mon Apr 11, 2016 9:54 am
I have done a screenshot of the error.
Capture d’écran 2016-04-11 à 11.53.09.png (44.35 KiB) Viewed 3629 times
dilipe
Postby Dean » Mon Apr 11, 2016 11:16 am
Postby dilipe » Mon Apr 11, 2016 12:14 pm
I have the same error with http and https. I have done a screenshot of my terminale
Capture d’écran 2016-04-11 à 14.12.53.png (20.51 KiB) Viewed 3622 times
dilipe
Postby Dean » Mon Apr 11, 2016 12:32 pm
Please try to ping 172.16.1.157
If the server is available, please specify the method of installation of ONLYOFFICE Server Version, the exact version installed and if all the products are up and running.
Next
