Documentserver cannot save
Postby thomaswollburg » Mon Sep 24, 2018 11:27 am
I try to run document server in an intranet setting using SSL. We have a valid wildcard certificate for both our web server and the connected Document Server.
This is how I start the docker container:
sudo docker run -e NODE_TLS_REJECT_UNAUTHORIZED=0 --dns 172.16.96.33 --name onlyoffice --add-host OURHOST:172.16.96.200 -i -t -d -p 443:443 -v /app/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data -v /app/onlyoffice/DocumentServer/logs:/var/log/onlyoffice -v /app/onlyoffice/DocumentServer/lib:/var/lib/onlyoffice -v /app/onlyoffice/DocumentServer/db:/var/lib/postgresql  onlyoffice/documentserver
Opening in a browser and inspecting the websocket I get this
Error in console
thomaswollburg
Re: Documentserver cannot save
Postby thomaswollburg » Thu Sep 27, 2018 11:48 am
Found out about this. The problem was in the default.json file where I had to set rejectUnauthorised to false.
thomaswollburg
Postby Carl » Thu Sep 27, 2018 12:21 pm
Does the Document Server function correctly now?
Postby thomaswollburg » Thu Sep 27, 2018 4:21 pm
Yeah, works fine so far.
thomaswollburg
