Can't install on Ubuntu 18.04?
Postby SparkyRih » Mon Jul 02, 2018 9:50 pm
I'm getting this error while trying to re-install onlyoffice-documentserver... I had it installed and working before, but while I was updating, an erro accured, so I removed onlyoffice-documentserver, but now I can't even install it anymore...
Setting up onlyoffice-documentserver (5.1.4-22) ...
dpkg: error processing package onlyoffice-documentserver (--configure):
installed onlyoffice-documentserver package post-installation script subprocess returned error exit status 127
Errors were encountered while processing:
User avatar
SparkyRih
Re: Can't install on Ubuntu 18.04?
Postby Maxim » Tue Jul 03, 2018 6:17 am
There must be problems with installation due to lack of some needed packages.
Onlyoffice doesn't support Ubuntu 18.04 for now.
Postby SparkyRih » Tue Jul 03, 2018 8:41 pm
Ok thanks, well than I'll see if I can find out what I'm missing to see if I can get it to work again...
User avatar
SparkyRih
