Windows Uninstall broken...
Postby mobamoba » Thu May 03, 2018 12:21 pm
Onlyoffice won't uninstall (or update) on Windows. The uninstaller starts then does absolutely nothing. Windows did a major OS update the other day and possibly that screwed it up. How do I manually uninstall Onlyoffice so the included uninstaller is broken? Thanks.
mobamoba
Re: Windows Uninstall broken...
Postby Maxim » Sun May 06, 2018 10:28 am
Hello mobamoba!
Please specify your Windows version and Onlyoffice version (what Onlyoffice product you mean).
