Install in Windows - How to do Part II
Postby waltergrimmvie » Sun Apr 22, 2018 5:09 am
I used this page to try to install the document server for testing:
https://helpcenter.onlyoffice.com/serve ... -apps.aspx
I installed the prerequisites etc, ran the program on port 442, the entries in Postgres ave been made,
BUT
I can simply not find out what to do next, the is no Program, i cannot start anything on the 127.0.0.1:442 or find any link to any kind of software,
Maybe i just skipped it after looking at the webpage for 2 hours, or maybe my IT knowledge is just too minor,
please help me find out how to get the SW running.
I do have some questions related so please inform me how to set up this initial stage on my server, and how the adaptations work.
thanxs
waltergrimmvie
Re: Install in Windows - How to do Part II
Postby Maxim » Thu Apr 26, 2018 12:55 pm
Hello waltergrimmvie!
You have installed the Document Server only, now you need to integrate it using our API or you can install Enterprise Edition or Community Edition (free and limited)
