Installing document server on raspbian
Postby Ilistro39 » Fri Apr 13, 2018 2:34 pm
I am trying to install ONLYOFFICE Document Server on raspbian with this tutorial. However when I update the repositories I get this error
pi@raspberrypi:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Get:2 http://download.onlyoffice.com/repo/debian squeeze InRelease [12.0 kB]
Hit:3 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:4 https://deb.nodesource.com/node_6.x stretch InRelease
Err:2 http://download.onlyoffice.com/repo/debian squeeze InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8320CA65CB2DE8E5
Reading package lists... Done
W: GPG error: http://download.onlyoffice.com/repo/debian squeeze InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8320CA65CB2DE8E5
E: The repository 'http://download.onlyoffice.com/repo/debian squeeze InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
and I find nothing on internet to solve it.
I hope you could help me and I thank you in advance. :)
Ilistro39
Re: Installing document server on raspbian
Postby Maxim » Thu Apr 19, 2018 1:19 pm
Hello Ilistro39!
You will fail because there is ARM processors in Raspberry Pi. Onlyoffice doesn't support ARM processors.
