Runtime Error Onlyoffice Community Server Debian + Ubuntu
Postby nyxtic » Mon Feb 05, 2018 10:21 pm
Hi. I did 10 instalations OnlyOffice Community Server on Ubuntu 14, 16, Debian 8, 9. With Node.js 8, 9 (no Docker).
1. Community server (Project, CRM, Peoples, Community) always work fine.
2. But Documents never. After click on the Document icon i just see Application Exception, Runtime Error at opened path http://10.0.0.187/products/files/. No error log. File inside server data path (web.config) make server permanent loading page. The same situation happen in Project menu Gantt diagram http://10.0.0.187/products/projects/ganttchart.aspx and Project menu / created My new project 1 /Documents http://10.0.0.187/products/projects/tmdocs.aspx?prjID=1
Document server is running on another LAN (10.0.0.186) IP address work (I'm able connect to the Document Server from NextCloud [10.0.0.160]). Creating new docs & edit doc files work fine.
3. In test from from another OnlyOffice Community Server instaled with Docker (10.0.0.189) I'm able connect to Document Server (10.0.0.186) too.
In fact after 2 days laboring.. I don't see the light :/ It exist ability to debug and repair? Thx for help.
nyxtic
Re: Runtime Error Onlyoffice Community Server Debian + Ubunt
Postby Maxim » Wed Feb 07, 2018 12:38 pm
Hello nyxtic!
Please specify what instruction you followed to install.
Describe how you tried to install step-by-step.
