Delete All USERS and GROUPS
Postby hillval » Mon Nov 20, 2017 9:30 pm
So I did an LDAP Sync and didn't correctly apply the filter and ended up imorting the entire AD directory with 1400+ groups and about three times as much users. How do I delete all users and groups in Bulk?
Thanks
hillval
Re: Delete All USERS and GROUPS
Postby Maxim » Tue Nov 21, 2017 7:19 am
Hello hillval!
Groups are deleted automatically if you fix the filter, but users simply block.
You need to delete them in the "People" module manually. Automatic deletion was replaced by disabling because public data of such users can be reassigned to other users.
