Disable document versioning
Postby bclauss » Wed Nov 15, 2017 10:29 am
Hey,
I installed Document Server on XUbuntu, all is zorking fine.
I have a question, can disable the cache files stored on the server ? I know that some datatable are empty after closing a document but there are still some files that are stored.
Thanks,
bclauss
bclauss
Re: Disable document versioning
Postby bclauss » Wed Nov 15, 2017 1:42 pm
I modify the default.json file but after a restart of the supervisor, nothing is happening.
 'files' : 60,
 "filesCron" : "*/1 * * * *",
sudo supervisorctl restart all
bclauss
Postby bclauss » Wed Nov 15, 2017 3:04 pm
I think it's working fine, sorry for the useless post...
bclauss
Postby Maxim » Tue Nov 21, 2017 10:27 am
Hello bclauss!
it's working fine
I think the same way.... ;)
