MySQL password
MySQL password
Postby nillenille2 » Mon Aug 14, 2017 5:16 pm
Hi!
I've recently changed my MySQL password. I've tried to change it in Onlyoffice as well – I've edited web.connections.config (and others), but for some reason the change gets rolled back. What am I doing wrong?
I'm running the Community Server on Debian (Installer).
Thanks!
nille
nillenille2
Re: MySQL password
Postby Maxim » Tue Aug 15, 2017 6:25 am
Hello nillenille2!
Please reproduce (describe step-by-step with commands you used) your scenario to change MySQL password to check it out.
Re: MySQL password
Postby nillenille2 » Tue Aug 15, 2017 11:04 am
Hi, I think I used something like
UPDATE mysql.user SET authentication_string = PASSWORD('123') WHERE User = 'root' AND Host = 'localhost'; flush privileges;
. Then stopped all services related to Onlyoffice and changed this line in the .config files:
<add name="default" connectionString="Server=localhost;Database=onlyoffice;User ID=root;Password=123;Pooling=true;Character Set=utf8;AutoEnlist=false" providerName="MySql.Data.MySqlClient"/>
Is there another way to change the password?
nillenille2
Re: MySQL password
Postby Maxim » Wed Aug 16, 2017 7:39 am
Hello nillenille2!
Try this command to change the root's password
docker exec -it ${MYSQL_CONTAINER_NAME} mysqladmin password "$MYSQL_ROOT_PASSWORD"
and this one to create user with password
CREATE USER '$MYSQL_MAIL_USER'@'localhost' IDENTIFIED BY '$MYSQL_MAIL_ROOT_PASSWORD';
Re: MySQL password
Postby nillenille2 » Wed Aug 16, 2017 10:11 am
Hi Maxim,
I don't use Docker. ;)
And I can log into MySQL with my new password.
nillenille2
Re: MySQL password
Postby Maxim » Thu Aug 17, 2017 8:22 am
Hello nillenille2!
I would advise you to make a mysql dump, make backup of /var/www/onlyoffice/Data and reinstall with correct pass.
