how to install document server in debian stretch (v9)
Postby alexoandro » Sun Jun 25, 2017 11:41 am
hello i need install document server in new debian ( debian stretch) but i dont see documentation and repository of debian stretch for doit installation.
i see doc for ubuntu 16.04 but repositorys is diferent of debian 9
please ,help me install in debian 9 ?
thanks
alexoandro
Re: how to install document server in debian stretch (v9)
Postby Maxim » Tue Jun 27, 2017 7:52 am
Hello alexoandro!
We currently have no separate instruction for debian 9. You should use this instruction, only change
echo
"deb http://archive.ubuntu.com/ubuntu precise main universe multiverse" | sudo tee -a /etc/apt/sources.list
to any mirror from here. Or you can try docker version.
Postby DoubleJ » Wed Sep 13, 2017 4:07 am
I hope you don't mind me hitching a ride on your topic, alexoandro. This is related to the new linux dist-upgrade as well. I upgraded from Debian 8 Jessie to Debian 9 Stretch and now openoffice-documentserver will not install the latest version.
sudo apt-get install onlyoffice-documentserver
Setting up onlyoffice-documentserver (4.4.3-7) ...
Generating AllFonts.js, please wait...Done
dpkg: error processing package onlyoffice-documentserver (--configure):
 subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
sudo DEBCONF_DEBUG=developer dpkg --configure onlyoffice-documentserver
debconf (developer): frontend started
debconf (developer): frontend running, package name is onlyoffice-documentserver
debconf (developer): starting /var/lib/dpkg/info/onlyoffice-documentserver.config configure
debconf (developer): <-- FSET onlyoffice/cluster-mode seen true
debconf (developer): --> 0 true
debconf (developer): <-- FSET onlyoffice/ds-port seen true
debconf (developer): <-- FSET onlyoffice/docservice-port seen true
debconf (developer): <-- FSET onlyoffice/spellchecker-port seen true
debconf (developer): <-- FSET onlyoffice/example-port seen true
debconf (developer): <-- INPUT medium onlyoffice/db-host
debconf (developer): --> 30 question skipped
debconf (developer): <-- INPUT medium onlyoffice/db-name
debconf (developer): <-- INPUT medium onlyoffice/db-user
debconf (developer): <-- GO
debconf (developer): --> 0 ok
debconf (developer): <-- INPUT critical onlyoffice/db-pwd
debconf (developer): <-- INPUT medium onlyoffice/rabbitmq-host
debconf (developer): <-- INPUT medium onlyoffice/rabbitmq-user
debconf (developer): <-- INPUT medium onlyoffice/rabbitmq-pwd
debconf (developer): <-- INPUT medium onlyoffice/redis-host
debconf (developer): <-- GET onlyoffice/db-host
debconf (developer): --> 0 localhost
debconf (developer): <-- GET onlyoffice/db-name
debconf (developer): --> 0 onlyoffice
debconf (developer): <-- GET onlyoffice/db-user
debconf (developer): <-- GET onlyoffice/db-pwd
debconf (developer): starting /var/lib/dpkg/info/onlyoffice-documentserver.postinst configure
debconf (developer): <-- GET onlyoffice/rabbitmq-host
debconf (developer): <-- GET onlyoffice/rabbitmq-user
debconf (developer): --> 0 guest
debconf (developer): <-- GET onlyoffice/rabbitmq-pwd
debconf (developer): <-- GET onlyoffice/redis-host
debconf (developer): <-- GET onlyoffice/cluster-mode
debconf (developer): --> 0 false
debconf (developer): <-- GET onlyoffice/ds-port
debconf (developer): --> 0 80
debconf (developer): <-- GET onlyoffice/docservice-port
debconf (developer): --> 0 8000
debconf (developer): <-- GET onlyoffice/spellchecker-port
debconf (developer): --> 0 8080
debconf (developer): <-- GET onlyoffice/example-port
debconf (developer): --> 0 3000
debconf (developer): <-- STOP
dpkg  --unpack /var/cache/apt/archives/onlyoffice-documentserver_4.4.3-7_amd64.deb
(Reading database ... 245079 files and directories currently installed.)
Preparing to unpack .../onlyoffice-documentserver_4.4.3-7_amd64.deb ...
Preparing for shutdown, it can take a lot of time, please wait...Done
Stoping documentserver services...
onlyoffice-documentserver:spellchecker: stopped
onlyoffice-documentserver:metrics: stopped
onlyoffice-documentserver:gc: stopped
onlyoffice-documentserver:docservice: stopped
onlyoffice-documentserver:converter: stopped
Unpacking onlyoffice-documentserver (4.4.3-7) over (4.4.3-7) ...
dpkg: warning: subprocess old post-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: ... it looks like that went OK
Processing triggers for fontconfig (2.11.0-6.7+b1) ...
rm /var/lib/dpkg/info/onlyoffice-documentserver.postinst -f
Reading package lists... Done
Building dependency tree
Reading state information... Done
onlyoffice-documentserver is already the newest version (4.4.3-7).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
It loads http://localhost/welcome/ but with 502 Bad Gateway nginx
nginx.error.log
[error] 17070#17070: *107 connect() failed (111: Connection refused) while connecting to upstream, client: IPHIDDEN, server: , request: "GET /welcome/ HTTP/1.1", upstream: "http://[::1]:8000/welcome/", host: "localhost"
[error] 17070#17070: *107 connect() failed (111: Connection refused) while connecting to upstream, client: IPHIDDEN, server: , request: "GET /welcome/ HTTP/1.1", upstream: "http://127.0.0.1:8000/welcome/", host: "localhost"
[error] 17070#17070: *107 no live upstreams while connecting to upstream, client: IPHIDDEN, server: , request: "GET /welcome/ HTTP/1.1", upstream: "http://docservice/welcome/", host: "localhost"
Any help would be appreciated. Thanks.
DoubleJ
Postby DoubleJ » Wed Sep 13, 2017 2:19 pm
I was able to get "Document Server is running" by doing the following...
apt-get install nginx
apt-get install nginx-extras
sudo apt purge onlyoffice-documentserver
sudo rm -rf /var/www/onlyoffice/documentserver
sudo apt-get --reinstall install onlyoffice-documentserver
I still received an error while installing but it did work. Would like to know still, what failed during the install process.
Keep an eye out on this github issue https://github.com/ONLYOFFICE/DocumentServer/issues/166 as this is where I got the idea to reinstall nginx. In my case, I believe there was a problem with the /etc/nginx/sites-available/default file.
DoubleJ
Postby Maxim » Thu Sep 14, 2017 6:42 am
Hello DoubleJ!
Great thanks for your information!
We tried to reproduce your issue on Debian 9 but have no luck, installation is ok.
