Err 81
Err 81
Postby gtech1 » Fri Apr 28, 2017 10:55 am
Basically it's the same issue as here, but the OP never posted his solution...
viewtopic.php?f=3&t=6450
Installed Community version of Document Server and I am attempting to create/edit a new file from ownCloud.
Installation and initial checks appear to complete ok but when opening the file in OnlyOffice, the error on screen is: "Download Failed"
and in the logs I see this: "type":"documentOpen","data":{"type":"open","status":"err","data":-81}
any clues as to what it might be ?
gtech1
Re: Err 81
Postby Maxim » Fri Apr 28, 2017 1:29 pm
Hello gtech1!
Is ownCloud accessible from Document Server?
You can try to ping ownCloud from document-server-container.
Re: Err 81
Postby gtech1 » Fri Apr 28, 2017 2:54 pm
Thank you, that was a solid tip.
Turns out that I had ownCloud encryption enabled and that won't work with Document Server. Disabled encryption and it now works
gtech1
