Presentation Editor - Unable to change size of table
Postby evanboyd » Sat Apr 22, 2017 12:39 am
Hello - I'm working in the Presentation editor and I can't seem to change the size of a table. The process - I create a new slide and insert a new table. I can modify the size of the cells within the table, however I can't modify the width and height of the table. I'm try to do this as you would in Microsoft PowerPoint, by hovering the mouse over the corner of the table and dragging the edge to change the height and width. The only thing I seem to be able to achieve is to change the position of the table. Any idea?
evanboyd
Re: Presentation Editor - Unable to change size of table
Postby Maxim » Mon Apr 24, 2017 8:07 am
Hello evanboyd!
It's not bug. Our developers are working on it. I cannot say when we are going to implement this option.
