Document dynamic editing problem
Postby dcolaco » Thu Mar 02, 2017 10:55 am
In document editor, i'm trying to append some text to the document dynamically, i tried editing the txt file generated but it doesnt reflect the changes in document.
I supose that the txt file only stores the initial state of the file and the changes are stored in mysql db, but is it possiple to insert a "change" in the database so it can be loaded to the editor?
Thanks in advance,
Regards
dcolaco
Re: Document dynamic editing problem
Postby Maxim » Fri Mar 03, 2017 1:32 pm
Hello dcolaco!
Unfortunately there is no way to insert a "change" in the database dynamically. It works another way.
