Language loading problem
Postby dcolaco » Thu Mar 02, 2017 10:50 am
I changed my document editor language to 'pt-PT' but i'm getting this error:
"Failed to load resource: the server responded with a status of 404 (Not Found)"
http://xxx.xxx.xxx.xxx/OfficeWeb/apps/d ... tents.json
I understand i'm missing some library but i couldnt find it for download, also if you can tell me where to install would be helpfull.
Thanks in advance,
Regards
dcolaco
Re: Language loading problem
Postby Maxim » Fri Mar 03, 2017 1:30 pm
Hello dcolaco!
Please specify what you did (step by step) to change document editor language.
Postby dcolaco » Tue Mar 14, 2017 4:12 pm
I've set in the editorConfig section the parameter lang to "pt-PT", although the editor language is in pt-PT the console throws the error 404 for "....OfficeWeb/apps/documenteditor/main/resources/help/pt/Contents.json"
Current config
"editorConfig": {
"lang": "pt-PT"
dcolaco
Postby Maxim » Wed Mar 15, 2017 11:20 am
Hello dcolaco!
This "library" is a help file which is not presented in OO. We have help files for some languages.
Postby dsi-lille » Wed Mar 15, 2017 3:00 pm
a little question about this topic : i can see with your link that the fr language is available for the help panel, but in our document server (Docker, edition enterprise) there is only english and russian.
Is it normal ?
can i copy the french help files and copy them in our server ?
Thanks,
Yoann
dsi-lille
Postby Maxim » Thu Mar 16, 2017 8:38 am
Hello Yoann!
These help files are not relevant to our days. Only english version is ok.
