Edit Comment permissions
Postby ckinsey » Fri Oct 21, 2016 4:19 pm
It seems that users can edit or delete any other users' comments. This is different from how MS Office works where a user can only modify their own comments. Is there a way to change this behavior from the API?
Currently using enterprise edition v3.7.
ckinsey
Re: Edit Comment permissions
Postby Maxim » Fri Oct 28, 2016 1:32 pm
In MS Office a user can modify comments of other users. But modifying of comments can be protected or turned off. There is no possibility to change that option in API.
