Default Spell Check Language
Postby cmachado » Fri Sep 23, 2016 10:16 am
Hi all,
How can we pre define the spell check language.
I want that by default the speel check to be done in pt-PT, but after I chage it on the document, when I re-open the document the language is changed back to US.
Is there any way we, changing one configuration, dedault this language.
Regards
Cristiano
cmachado
Re: Default Spell Check Language
Postby Eugenie » Tue Sep 27, 2016 2:53 pm
Cristiano,
To avoid the issue you need to choose document language for the whole document http://take.ms/8W7Pc
Eugenie
Postby cmachado » Thu Dec 29, 2016 6:28 pm
Thanks for your help.
I applied to the whole document and it worked, but the next time I opened the document the speel check returned to the default values (in this case US).
IS there any way were I can define the spell language to be used I I invoke the document to open it?
Maybe o the settings?
I have the community edition
Thanks
Regards
Cristiano
cmachado
