Error when compiling document server v4.1.0, Ubuntu 16.04
Postby keepo » Wed Sep 14, 2016 2:28 pm
core version 4.1.0
I was following this article to compile document server locally
http://helpcenter.onlyoffice.com/server ... -code.aspx
but i got this error,
../memorystream.h:39:16: fatal error: v8.h: No such file or directory
and after I install libv8-dev, i got another one
../memorystream.h:40:37: fatal error: libplatform/libplatform.h: No such file or directory
Did I miss something?
keepo
Re: Error when compiling document server v4.1.0, Ubuntu 16.0
Postby Eugenie » Fri Sep 16, 2016 3:45 pm
Could you describe your actions step by step and specify the exact moment (step) the issue appears.
We will be gald to help you.
Eugenie
Postby keepo » Sat Sep 17, 2016 9:38 am
Eugenie wrote:Hello,
I follow compile icu, install v8 as module.
Then build the core, "cd core && make" and I got that error.
keepo
Postby Pavel.Lobashov » Wed Sep 21, 2016 11:55 am
@keepo
Hi, I re-check all the steps prior
cd core && make
and it works fine for me on Ubuntu 16.04
Could you check that step
CFLAGS="-fPIC" CXXFLAGS="-fPIC" make native
for v8 finished correctly?
As far as I understand on some systems there is this error while trying to compile v8
unsupported reloc 42 against global symbol __gmon_start__
and I fixed like mention in this thread
by executing command
rm third_party/binutils/Linux_x64/Release/bin/ld.gold
ln -s /usr/bin/ld.gold third_party/binutils/Linux_x64/Release/bin/ld.gold
Pavel.Lobashov
Postby Pavel.Lobashov » Wed Sep 21, 2016 1:47 pm
@keepo
We reproduced problem on one system, looking for a way to fix it.
Pavel.Lobashov
Postby keepo » Thu Sep 22, 2016 7:16 am
Pavel.Lobashov wrote:@keepo
cd core && make
Did you compile 4.1.0 or above? I have no problem compiling 4.0.3 version.
keepo
Postby Eugenie » Tue Sep 27, 2016 3:12 pm
Our developers are working on solving the issue.
We are sorry for the inconveniences!
Eugenie
