[Resolved]PDf Preview = Error conversion!?
Postby Kpol » Mon Apr 04, 2016 1:03 pm
I simply upload a simple PDF (1page 32ko). All fine, when i click on it just for a preview, it opens the docx editor (!?) instead of a simple preview... Since when we need a conversion to view a simple PDF ??...
This was ok with your older version 8.6x ... :roll:
onlyo v. 8.7x
User avatar
Kpol
Re: PDf Preview
Postby Kpol » Mon Apr 04, 2016 1:25 pm
i want to mention that in v 8.6 it this ok... In v 8.7x it is not.
v8.6x link (OK) - Here you have a normal preview of the PDF.
v 8.7x link (Not OK!) - Here you have the error mention above... :(
Hope it helps....
User avatar
Kpol
Re: PDf Preview = Error conversion !??
Postby Dean » Wed Apr 06, 2016 8:17 am
Please change those strings:
In the files:
var/www/onlyoffice/WebStudio/web.appsettings.config
var/www/onlyoffice/WebStudio2/web.appsettings.config
Delete the parameter '.pdf' from the string:
<add key="files.docservice.viewed-docs"
And restart the containers.
Postby Kpol » Fri Apr 08, 2016 4:06 pm
Ok thanks, thats do the trick!
ps : When something work, please keep it as it! Thanks a lot! :)
User avatar
Kpol
Re: [Resolved]PDf Preview = Error conversion!?
Postby akeskinen » Fri Apr 29, 2016 3:57 pm
I had same problem.
Every pdf tried to open in editor and gave "Convertation error" popup (I guess that is meant to be conversion error).
I removed .pdf from string. Now it still tries to open document editor but announces that file type is not supported.
I have latest version. How can I get pdf preview?
akeskinen
Postby akeskinen » Fri Apr 29, 2016 4:09 pm
Dean wrote:Hello,
In the files:
Didn't help for me. Url is still incorrect but edit says pdf is not supported.
akeskinen
Postby Kpol » Wed May 04, 2016 7:55 am
Hey guys,
onlyoffice v. 8.7x
Not sure 100% for other version, pls check...
User avatar
Kpol
Postby Dean » Thu May 05, 2016 11:57 am
akeskinen wrote:I had same problem.
Do you also use 3.0 Editors + 8.7 Community?
Postby nexusefr » Tue May 24, 2016 2:47 pm
Hello all, yes i use 8.7 under Windows 8 and 3.0 under lubuntu (ubuntu 15.10 x64), i removed .pdf from string and i get error "file type is not supported" . How can i know the doc server version under ubuntu ?
Thanks!
soz for my english :roll:
nexusefr
Postby Dean » Mon May 30, 2016 7:57 am
Did you use dokcer to install Document Server or you were using a deb-package?
Next
