Problems opening CSV files
Postby leio10 » Wed Feb 10, 2016 12:34 pm
I'm running the open source version of DocumentServer 3.0. Editor is working properly with XML formats, but I'm having problems when I try to open CSV files.
It allows me to select the encoding and field separator (by the way, I didn't find a way to change it later if I choose wrong, even reopening the file, it is possible?), but then it ignores my selection. I've open the "settings.json" file stored with the uploaded file and the Editor.bin, and it seems to be ok, with the choosen values, but the encoding used by the editor is always the same (ASCII or similar, instead of UTF8 that I select) and the separator is always the default (,).
I've tested the same operation on your online trial service and it works properly, so I suppose that the problem could be in my server configuration, or maybe there is a bug in the open source version code.
Could you help me with this?
Regards
leio10
Re: Problems opening CSV files
Postby Alex » Wed Mar 16, 2016 8:40 am
I regret to inform you that there is an issue with opening csv files in the 3.0 version
There is no public fix available
Alex
