Errors in auto saving documents to file server
Postby careylipu » Thu Jul 26, 2018 1:51 am
Hi Support team,
we can not save document from document server to file server when the document is not closed.
we want to auto save document form document server to file server.
we have set :
1.autoAssembly is true (/etc/onlyoffice/documentserver/default.json)
2.forcesave: true (/var/www/onlyoffice/documentserver/web-apps/apps/api/documents/api.js)
Regards
Carey
careylipu
Re: Errors in auto saving documents to file server
Postby Maxim » Thu Jul 26, 2018 7:10 am
Hello careylipu!
If forcesave is not initiated you are not able to save a document, session must be closed which is a signal for the document server to collect the changes and send from the document editor into one document.
Please see more information here
