Error while downloading folder
Postby csloh » Wed May 23, 2018 10:26 am
I have a folder on document server which contains a lots of file. The size of the folder is about 4GB.
While I'm trying to download the whole folder, document server is actually archiving the folder into a zip file.
But there is an while archiving, it said "File larger than 100MB will not be archived"
Is there a setting for me to change 100MB to 10GB? Thanks.
csloh
Re: Error while downloading folder
Postby Maxim » Thu May 24, 2018 11:23 am
Hello csloh!
Actually the Document Server doesn't keep files.
I suppose you mean Community Server (like a part of Onlyoffice Enterprise Edition or Community Edition).
But i have downloaded 500 Mb file and downloaded it again.
Please specify what Onlyoffice product you have installed you work with.
