Resizing charts doesnt work
Postby linuxpro » Tue Oct 24, 2017 8:46 pm
Hey,
I'm new to Onlyoffice, but very impressed with your work.
However, I have a few problems. I use OnlyOffice 4.4.1.338 on Linux.
I can't resize charts in the presentation-programm by dragging at the little squares. It just shows the "hand symbol" and moves the whole chart.
Is there a way to change that?
It does work with AutoForms and images, but not with the sheets, which is very anoying.
Thank you very much!
linuxpro
Re: Resizing charts doesnt work
Postby Maxim » Mon Oct 30, 2017 12:08 pm
Hello linuxpro!
Thank you for the information!
We will check it.
