Error upload document
Postby cgomez » Wed Aug 30, 2017 8:58 am
I have a problem when I try to upload any document, I only get error, it does not give me any ID of it, can you pass the complete configuration of the documents part?
cgomez
Re: Error upload document
Postby Maxim » Wed Aug 30, 2017 9:08 am
Hello cgomez!
There can be a lot of reasons. Please specify what instruction did you follow to install Onlyoffice? What is OS of your host machine? Attach screenshot please. Give us more info please to help you.
Postby cgomez » Wed Aug 30, 2017 10:17 am
I installed the community edition, and I configured the web on port 82 since the 80 was in use
Error
cgomez
Postby cgomez » Wed Aug 30, 2017 10:42 am
Maxim wrote:Hello cgomez!
SO.: Windows Server R2 Foundation
OnlyOffice CommunityEdition
I sent you a screenshot of the error
Error
cgomez
Postby Maxim » Thu Aug 31, 2017 6:50 am
Hello cgomez!
1 Please check ONLYOFFICE services
2 How did you configure 82 port?
Postby BranKo » Wed Oct 11, 2017 7:17 am
Ihave the same error but my onlyoffice is on :80.
This error appear after upgrade (but I don't know which upgrade because I don't use upload)
I looked in /var/log but I can't find any interesting.(on community server)
BranKo
Postby Maxim » Thu Oct 12, 2017 7:02 am
Hello BranKo!
Please specify how you updated Onlyoffice. You are using Onlyoffice for docker?
Postby BranKo » Thu Oct 12, 2017 9:23 am
No I have onlyoffice installed on Ubuntu linux 14.03 with fixed kernel version due to compatibility list.
Update was done apt update && apt full-upgrade with reboot.
BranKo
Postby ichineesan » Sun Oct 22, 2017 9:41 am
i also have the same error issue.. using docker and onlyoffice install script
ichineesan
Postby rmx » Mon Dec 11, 2017 5:49 am
Same problem for me, using Docker Community + Document + MySQL. Can't upload documents.
rmx
Next
