Problem to export iCal calendar
Postby aruizr23 » Tue Jun 06, 2017 5:06 pm
Hello everyone,
I recently installed onlyoffice communiti server version 17.05.113 and it works great, however, I recently wanted to export the calendars of my projects in ical format but I mark error. The display shows me the following:
{"Status": 0, "statusCode": 200, "response": {}}
And checking the logs shows me the following error:
2017-06-06 16:31:15,059 ERROR [Threadpool worker] ASC.Calendar - System.TypeInitializationException: The type initializer for 'Ical.Net.Utility.DateUtil' threw an exception. ---> NodaTime.TimeZones.DateTimeZoneNotFoundException: TimeZoneInfo Local ID is unknown to source TZDB: 2015a (mapping: 10930)
It should be mentioned that this does not happen to me when I export "my calendar", the problem is with the calendars of the "other calendars" section.
Also I already update the time zone on my server which already matches the time zone that I have configured in onlyoffice, I have restarted the server and nothing.
Any suggestions?
aruizr23
Re: Problem to export iCal calendar
Postby Maxim » Wed Jun 07, 2017 7:56 am
Hello aruizr23!
Thank you for the information you provided, we have already fixed it and add this fix to the next update.
Postby aruizr23 » Wed Jun 07, 2017 4:17 pm
Thank's, Is there an approximate release date of the new version?
aruizr23
Postby Maxim » Tue Jun 13, 2017 11:25 am
Hello aruizr23!
Unfortunately there is no an approximate release date, but soon.
