FileExtension supported by onlyoffice
Postby NI3 » Tue Apr 25, 2017 7:29 am
I have deployed Integration Edition of OnlyOffice server on Windows. Now I came to know that few file formats such as docm, .png, .jpg etc are not supported while few are supported by onlyoffice server for editing. So I wanted to know the configuration on server where the list of supported and unsupported files can be found?
Where does the server exactly maintain the lists of supported and unsupported file extensions?
NI3
Re: FileExtension supported by onlyoffice
Postby Maxim » Tue Apr 25, 2017 11:19 am
Hello NI3!
Supported Formats of Electronic Documents
Supported Formats of Spreadsheets
...formats such as docm, .png, .jpg etc are not supported while few are supported by onlyoffice server for editing.
In Document Editor, you can insert images in the most popular formats into your document. The following image formats are supported: BMP, GIF, JPEG, JPG, PNG.
