Delete files from server
Postby NI3 » Wed Apr 12, 2017 2:09 pm
For security purpose I want to delete the file from editor server as soon as it is loaded on browser for editing. I am using storage server in java so how to achieve it in java?
NI3
Re: Delete files from server
Postby Maxim » Fri Apr 14, 2017 7:41 am
Hello NI3!
Do you mean to delete file while it is open and it is editing in browser?
Postby NI3 » Mon Apr 17, 2017 3:19 am
Yes...
I want to know the flow in 2 scenarios:
1. Delete file while it is open for editing in browser
2. After editing is done
NI3
Postby Maxim » Mon Apr 17, 2017 8:17 am
Hello NI3!
There is no such way (like command "forcesave" whach saves the file, but you can use command drop
You can delete file in document manager.
