Documents server HDD size?
Postby Kpol » Fri Feb 26, 2016 5:03 am
If I get, all space need to stock files etc.. is in community server, correct?
So document server can be in a "small" HDD (40gb should be enough, correct ?).
K.
User avatar
Kpol
Re: Documents server HDD size?
Postby Dean » Fri Feb 26, 2016 5:40 am
40 Gb is even more than enough. All the files stored in the Doc Serv are logfiles.
Postby Kpol » Fri Feb 26, 2016 5:51 am
ah great ! thxs !
k.
User avatar
Kpol
