VM Hypervisor recommend?
Postby Kpol » Wed Feb 17, 2016 12:32 pm
We plan to reinstall our onlyoffice on a VM. Is there any recommend ? VMWare, Xen, KVM .. Else?
K.
User avatar
Kpol
Re: VM Hypervisor recommend?
Postby Dean » Wed Feb 17, 2016 12:51 pm
Our recommendations are to use VirtualBox, as far as it is the basic platform we use in our tests and everything goes correct.
Postby Kpol » Wed Feb 17, 2016 1:32 pm
Oh, really...
Last week,I experimented onlyoffice with Xen, it consume some cpu and especially RAM and Vbox is not really the best in term of performance...
In the next I will try on Vmware ...
Thanks anyway for your answer.
K.
User avatar
Kpol
