Ads...?
Ads...?
Postby Kpol » Tue Nov 10, 2015 5:36 am
I understand that we use something free but is there a way to not receive this :
Screen Shot 2558-11-10 at 12.31.09 PM.png (201.58 KiB) Viewed 1876 times
.. Of course i tried to unsuscribe here...
Screen Shot 2558-11-10 at 12.32.59 PM.png (117.2 KiB) Viewed 1876 times
But if u click (And i think you know..) It comes direct here ...
User avatar
Kpol
Re: Ads...?
Postby AnaMih » Thu Nov 12, 2015 1:52 pm
Thanks a lot for using our service.
Sorry for the inconveniences, the issue will be resolved in one of the next versions.
Now you can to make the following:
add the line <add key="core.notify.tariff" value="false" />
to the file /var/www/onlyoffice/WebStudio/web.appsettings.config (in container with Community Server if you use Docker version)
It will help you avoid this type of notifications.
It is recommended to restart service monoserve after changing the config-file.
You also can customize the type of notification letters in source code: public void SendTariffWarnings(DateTime scheduleDate)
in web\studio\ASC.Web.Studio\Core\Notify\StudioNotifyService.cs
For example look for lines:
#region 3 days after registration
#endregion
#region 7 days after registration
User avatar
Re: Ads...?
Postby Kpol » Thu Nov 12, 2015 5:14 pm
Ok noted! Thank you.
Update :
I dont find.. Where exactly ? :?
User avatar
Kpol
Re: Ads...?
Postby AnaMih » Fri Nov 13, 2015 4:27 pm
You should edit the source code. The file is here.
User avatar
