502 Bad Gateway
Re: 502 Bad Gateway
Postby HyperGlide » Tue Jun 16, 2015 7:40 am
Dean wrote:We have fixed it in a current version and will release it soon, Sorry for the inconvenience!
Can you give a date on when "Soon" is please.
Thank you.
HyperGlide
Re: 502 Bad Gateway
Postby Dean » Wed Jun 17, 2015 6:07 am
It was in fact released. Now the 8.5.211 version includes the Kernel version auto-check, and it helps to fix the 502 issue.
Re: 502 Bad Gateway
Postby HyperGlide » Wed Jun 17, 2015 3:11 pm
Dean wrote:It was in fact released. Now the 8.5.211 version includes the Kernel version auto-check, and it helps to fix the 502 issue.
Thank you!
HyperGlide
Previous
