Migration (Linux server)
Postby Kpol » Sun May 17, 2015 1:36 pm
Ok I see good new here
http://www.onlyoffice.com/blog/2015/04/document-server-3-0-release-and-other-news-for-open-source-community-2/
But actually we are on this vers.
Question = Do you have solution for me to migrate ?
Thanks a lot!.
ps = Ubuntu server.
User avatar
Kpol
Re: Migration (Linux server)
Postby AnaMih » Wed May 20, 2015 3:12 pm
For migrating from 8.1 to 8.5 follow the instructions:
1) Created BD dump, make a backup of /opt/onlyoffice/Data
2) Remove OnlyOffice 8.1
sudo apt-get remove onlyoffice (please do not remove any files manually)
3) Install OnlyOffice 8.5
sudo apt-get install onlyoffice-communityserver
Database and all necessary files should be picked up automatically
User avatar
Postby Kpol » Sat May 23, 2015 2:21 pm
Ok i see. I ll sure do it.
Thanks for advice.
Khampol.
User avatar
Kpol
Postby Kpol » Mon May 25, 2015 4:41 am
In fact i plan to use version DOCKER (+ubuntu svr). You also suggest to do the same way?
User avatar
Kpol
Postby Dean » Wed May 27, 2015 7:18 am
AnaMih wrote:For migrating from 8.1 to 8.5 follow the instructions:
To upgrade to Docker-Community Server after performing these steps (it is necessary to upgrade to 8.5 because of difference in DB) please do the following:
Create BD dump, make a backup of /opt/onlyoffice/Data once more
sudo apt-get remove onlyoffice-communityserver
Reboot the machine
Install Docker
sudo apt-get install docker.io
Install ONLYOFFICE
sudo docker run -i -t -d -p 80:80 -p 443:443 -v /opt/onlyoffice/Data:/var/www/onlyoffice/Data \
--link onlyoffice-mail-server:mail_server \
--link onlyoffice-document-server:document_server \
onlyoffice/communityserver
Edit the command if you don't need any components.
Copy the DB into /opt/onlyoffice/Data , restore it.
Copy the Data folder into the container.
Check the portal data.
If you get any issues with it, please, contact us.
Postby Kpol » Thu May 28, 2015 4:34 pm
OK, I see. Thanks.
Little more questions :
In the process you dont talk at all about "files" ( Files in Documents /attach in projects etc.. ). Where are they ? And what to do for migrate them as well?
User avatar
Kpol
Postby Dean » Mon Jun 01, 2015 11:28 am
They are also stored in the /var/www/onlyoffice/Data folder inside the container. So, in the backup of the folder process you will backup those files also.
Postby Kpol » Tue Jun 02, 2015 10:17 am
Dean wrote:They are also stored in the /var/www/onlyoffice/Data folder inside the container. So, in the backup of the folder process you will backup those files also.
Ok i see, i have just to copy all here in the same path in new onlyoffice version and it should recongnize all.
thanks.
User avatar
Kpol
Users browsing this forum: Baidu [Spider] and 1 guest
