Bad configuration for monit/monoserve
Postby bobleponge » Mon May 11, 2015 12:49 pm
Actually, monoserve can crash (does crash after a while on my system), but is not restarted because none of the trigger in monit's script file leads to a restart in that case.
The /etc/monit/conf.d/monoserve should read:
check process monoserve
    matching "fastcgi-mono-server4"
    start program = "/etc/init.d/monoserve start" with timeout 60 seconds
    stop program  = "/etc/init.d/monoserve stop"
    if memory usage > 80% then restart
    if cpu > 80% for 5 cycles then restart
    if loadavg(5min) greater than 10 for 8 cycles then stop
    if failed host port 8086 then restart
    if 5 restarts within 5 cycles then timeout
Last two lines will restart monoserve when it crashes.
Re: Bad configuration for monit/monoserve
Postby AnaMih » Thu May 14, 2015 2:49 pm
We are sorry for the inconveniences. The issue like this is currently in the stage of testing. We are working to solve the problem. As soon as it is fixed, the bugfix will appear on our site. If you have any more information, please let us know.
User avatar
