The file cannot be accessed right now.
Postby jbakuwel » Fri Oct 12, 2018 2:51 am
Hi there,
OnlyOffice running on Debian Linux 9, DEB version 5.1.5-59
ii onlyoffice-communityserver 9.6.3.691
ii onlyoffice-documentserver 5.1.5-59
ii nodejs 6.14.4-1nodesource1
I frequently get the message "The file cannot be accessed right now" when editing a document and there is a corresponding (?) message in /var/log/onlyoffice/documentserver/docservice/out.log:
[2018-10-12 15:16:52.742] [WARN] nodeJS - error description: docId = NYN_utBwQv3IJIB2hzM_ errorId = Update Version error
[2018-10-12 15:17:10.776] [WARN] nodeJS - error description: docId = NYN_utBwQv3IJIB2hzM_ errorId = Update Version error
[2018-10-12 15:17:44.686] [WARN] nodeJS - error description: docId = SJRvcNSFvfJMmkMf8eE_ errorId = Update Version error
[2018-10-12 15:30:36.526] [WARN] nodeJS - error description: docId = kn5b5KfW0opp6pY78VY_ errorId = Update Version error
There is a reference on this board suggesting I increase the verbosity of the log that contains instructions how to do that but that is for an owncloud instance??
kind regards,
Jan
jbakuwel
Re: The file cannot be accessed right now.
Postby Carl » Mon Oct 15, 2018 10:32 am
Hello Jan,
Please try to update the document server to version 5.2 and check if the issue persists.
As for logging, you can increase its level in this config /etc/onlyoffice/documentserver/log4js/production.json ("nodeJS": "WARN" => "ALL")
