(BUG) Interface of OnlyOffice unusable small
Postby winklehner » Thu Sep 06, 2018 12:20 pm
There seems to be a bug in the current OnlyOffice (we are using the integrator version). On a MacBook < 15 inch the
interface of OnlyOffice is unusable small. This might be related to the retina display and scaling.
Any solutions?
OnlyOffice on MacBook
winklehner
Re: (BUG) Interface of OnlyOffice unusable small
Postby Carl » Fri Sep 21, 2018 11:35 am
Can you please specify the version of Document Server you have? Also specify the version of MacOS and browser you use.
Postby winklehner » Fri Nov 30, 2018 1:14 pm
MacOSX 10.14.1, Chrome 70.0.3538.11.0, Apple MacBook A1502.
DocumentServer 5.2.2.
winklehner
