The file can not be accessed right now...
Postby dobiaki » Wed Mar 28, 2018 8:42 am
Sorry for my english, i have install the onlyoffice server with https and in other server owncloud with https too, everything seems to work good but when i want to edit a document, i've got the message "WARNING - The file can not be accessed right now".
What can i do to resolve this problem please.
Thanks in advance !
dobiaki
Re: The file can not be accessed right now...
Postby Maxim » Thu Mar 29, 2018 12:17 pm
Hello dobiaki!
It needs to see your logs. You may follow this instruction to set logs level to 0. Then try to open docs.
