[Community Server] Problem to compile v9.6.572
Postby dsi-lille » Fri Mar 16, 2018 9:38 am
i downloaded the sources of the latest Community Server version (v9.6.572) and when i tried to compile it on Windows (by using BuildAndDeploy script) i get the following error :
ÉCHEC de la build.
       "c:\ONLYOFFICE_CommunityServer\v9.6.572-modif\build\msbuild\build.proj"
       (cible par défaut) (1) ->
       "c:\ONLYOFFICE_CommunityServer\v9.6.572-modif\web\studio\ASC.Web.Studio\
       ASC.Web.Studio.csproj" (ReBuild cible) (22) ->
       (CoreCompile cible) ->
         CSC : error CS2001: Impossible de trouver le fichier source 'UserContr
       ols\Management\SingleSignOnSettings\SsoSettingsV2.cs' [c:\ONLYOFFICE_Com
       munityServer\v9.6.572-modif\web\studio\ASC.Web.Studio\ASC.Web.Studio.csp
       roj]
       ols\Management\SingleSignOnSettings\SsoUserData.cs' [c:\ONLYOFFICE_Commu
       nityServer\v9.6.572-modif\web\studio\ASC.Web.Studio\ASC.Web.Studio.cspro
       j]
    0 Avertissement(s)
    2 Erreur(s)
Indeed, the folder SingleSignOnSettingsthose is missing from the sources...
Thanks for your help,
Yoann
dsi-lille
Re: [Community Server] Problem to compile v9.6.572
Postby Maxim » Fri Mar 16, 2018 9:49 am
Hello Yoann!
Thank you for your information we will check this out!
