Error with history events
Postby nillenille2 » Tue Dec 13, 2016 11:20 am
Hi! I get this error when the system tries to create an event in the contact history.
2016-12-13 11:54:07,917 WARN  [Threadpool worker] ASC.Api - Problem with adding history event to CRM. mailId=9317
System.ApplicationException: Error retrieving response. Check inner details for more info. ---> System.Net.WebException: Error: SecureChannelFailure (The authentication or decryption has failed.) ---> System.I
O.IOException: The authentication or decryption has failed. ---> System.IO.IOException: Error while sending TLS Alert (Fatal:InternalError): System.IO.IOException: The authentication or decryption has failed.
---> Mono.Security.Protocol.Tls.TlsException: The authentication or decryption has failed.
  at Mono.Security.Protocol.Tls.RecordProtocol.EndReceiveRecord (System.IAsyncResult asyncResult) [0x00040] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.SslClientStream.SafeEndReceiveRecord (System.IAsyncResult ar, System.Boolean ignoreEmpty) [0x00000] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.SslClientStream.NegotiateAsyncWorker (System.IAsyncResult result) [0x00071] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.SslClientStream.EndNegotiateHandshake (System.IAsyncResult result) [0x0003b] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallback (System.IAsyncResult asyncResult) [0x0000c] in <1d0bb82c94e7435eb09324cf5ef20e36>:0  ---> System.IO.IOException: Unable to write data to the transport connection: The socket has been shut down. ---> System.Net.Sockets.SocketException: The socket has been shut down
  at System.Net.Sockets.Socket.EndSend (System.IAsyncResult result) [0x00033] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x0005f] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x000af] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at Mono.Security.Protocol.Tls.RecordProtocol.EndSendRecord (System.IAsyncResult asyncResult) [0x00040] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.RecordProtocol.SendRecord (Mono.Security.Protocol.Tls.ContentType contentType, System.Byte[] recordData) [0x0000b] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.RecordProtocol.SendAlert (Mono.Security.Protocol.Tls.Alert alert) [0x00027] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.RecordProtocol.SendAlert (System.Exception& ex) [0x00021] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Security.Protocol.Tls.SslStreamBase.EndRead (System.IAsyncResult asyncResult) [0x00057] in <1d0bb82c94e7435eb09324cf5ef20e36>:0
  at Mono.Net.Security.Private.LegacySslStream.EndAuthenticateAsClient (System.IAsyncResult asyncResult) [0x00011] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at Mono.Net.Security.Private.LegacySslStream.AuthenticateAsClient (System.String targetHost, System.Security.Cryptography.X509Certificates.X509CertificateCollection clientCertificates, System.Security.Authentication.SslProtocols enabledSslProtocols, System.Boolean checkCertificateRevocation) [0x0000e] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at Mono.Net.Security.MonoTlsStream.CreateStream (System.Byte[] buffer) [0x00044] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at System.Net.HttpWebRequest.EndGetRequestStream (System.IAsyncResult asyncResult) [0x00043] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at System.Net.HttpWebRequest.GetRequestStream () [0x00057] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at RestSharp.Http.WriteRequestBody (System.Net.HttpWebRequest webRequest) [0x00034] in <f1571fe5cebd42168196f091576fbb71>:0
  at RestSharp.Http.PostPutInternal (System.String method) [0x00015] in <f1571fe5cebd42168196f091576fbb71>:0
  at RestSharp.Http.AsPost (System.String httpMethod) [0x00007] in <f1571fe5cebd42168196f091576fbb71>:0
  at RestSharp.RestClient.DoExecuteAsPost (RestSharp.IHttp http, System.String method) [0x00000] in <f1571fe5cebd42168196f091576fbb71>:0
  at RestSharp.RestClient.Execute (RestSharp.IRestRequest request, System.String httpMethod, System.Func`3[T1,T2,TResult] getResponse) [0x00022] in <f1571fe5cebd42168196f091576fbb71>:0
  at ASC.Mail.Aggregator.Common.ApiHelper.Execute (RestSharp.RestRequest request) [0x000a8] in <51a1114efab74314a432fcbabdf935ed>:0
  at ASC.Mail.Aggregator.Common.ApiHelper.AddToCrmHistory (ASC.Mail.Aggregator.Common.MailMessage message, ASC.Mail.Aggregator.Common.CrmContactEntity entity, System.Collections.Generic.IEnumerable`1[T] fileIds) [0x00137] in <51a1114efab74314a432fcbabdf935ed>:0
  at ASC.Mail.Aggregator.Dal.CrmHistoryDal.AddRelationshipEvents (ASC.Mail.Aggregator.Common.MailMessage message) [0x001bf] in <8ebb122af20146308d0fd7dfb13ec99b>:0
  at ASC.Mail.Aggregator.MailBoxManager.AddRelationshipEventForLinkedAccounts (ASC.Mail.Aggregator.Common.MailBox mailbox, ASC.Mail.Aggregator.Common.MailMessage messageItem, System.String httpContextScheme, ASC.Mail.Aggregator.Common.Logging.ILogger log) [0x00054] in <8ebb122af20146308d0fd7dfb13ec99b>:0
The request goes to https://subdomain/api/2.0/crm/history.json instead of https://subdomain.domain.tld/api/2.0/crm/history.json – is there a way to fix this?
nillenille2
Re: Error with history events
Postby John » Wed Dec 14, 2016 12:03 pm
Please specify what version of Community Server do you use. Try to update it if it's outdated.
Try to perform this: attach container with Community Server and edit the file
/var/www/onlyoffice/Services/MailAggregator/ASC.Mail.Aggregator.CollectionService.exe.config
Find the string
<add key="api.host" value="" />
and put your value "subdomain.domain.tld" between quotes (marked red on the screenshot).
If this string doesn't exist put "subdomain.domain.tld" in the string
<add key="core.base-domain" value="" />
(marked green on the screenshot).
Thank you for the interest in our product.
John
Postby nillenille2 » Thu Dec 15, 2016 12:21 pm
Thank you for your reply.
I've changed the values, but it didn't do the trick… It still tries to connect to the hostname instead of the FQDN. Or do I need to add a port or change core.host as well?
2016-12-15 12:50:01,779 DEBUG [Threadpool worker] ASC.Api - ApiHelper->Execute: request url: https://hostname/api/2.0/people/filter.json?filterValue={FilterValue}&StartIndex={StartIndex}&Cou
nt={Count}
2016-12-15 12:50:01,780 DEBUG [Threadpool worker] ASC.Api - ApiHelper->Execute: request url: https://hostname/api/2.0/crm/contact/simple/byEmail.json
I'm running the current version of the community server on Debian Jessie.
nillenille2
Postby nillenille2 » Wed Mar 15, 2017 12:28 pm
For some reason the issue has been resolved.
I don't think I've updated Onlyoffice… Though I did update Mono, recently.
nillenille2
Postby Maxim » Thu Mar 16, 2017 5:57 am
Hello nillenille2!
Think about update. Maybe you should.
Return to Notification issues
