Project User
Project User
Postby frk89 » Thu Dec 03, 2015 11:39 am
Hi!
Can u please tell how does other users apart from admin can create projects.
Since they are just able to create tasks and discussions not projects.
Can we make other users admin??
Also,
I have installed onlyoffice-communityserver and i am not able to edit the files can only upload them or share them with users.Or do i have to install document server separately for online editing.
i am using linux server and not docker.
frk89
Re: Project User
Postby Dean » Thu Dec 03, 2015 1:35 pm
Yes, for sure, you can make user an admin to create projects. To do it, please:
  • switch to the portal settings choosing the Settings option in the top menu
  • select the Access Rights option on the left-side panel
  • click the Show link next to the Administrators caption
  • click the Choose user link under the list of administrators
  • select a person or several persons at once from the existing users/guests or create a new administrator right here by clicking the Create new profile link
Yes, you can edit files only if you use Document Server.
Please find documentation and instructions for installing and connecting it here: (Please note, that it must be installed on the separate server from the Community)
http://helpcenter.onlyoffice.com/server/linux/document/linux-installation.aspx
http://helpcenter.onlyoffice.com/server/linux/document/connect-document-server.aspx
Re: Project User
Postby frk89 » Mon Dec 07, 2015 8:56 am
Hi Dean!
Thanks.
frk89
Return to Notification issues
