SSL configuration not working
Postby bobleponge » Thu May 07, 2015 9:07 am
Currently, when using SSL for SMTP or IMAP, OO does not work (it hangs almost forever).
Without SSL, it works, but obviously, I'd prefer if data where not in clear
bobleponge
Re: SSL configuration not working
Postby Dean » Thu May 07, 2015 11:37 am
Could you please specify SMTP/IMAP settings (port, server)?
If you use port 587, please, try to use 465.
Postby bobleponge » Mon May 11, 2015 12:56 pm
My IMAP server is "ssl0.ovh.net", it listens on SSL port 993 with authentication. It also listen on port 143 for non-SSL IMAP (with authentication).
For SMTP, the address is the same, it listens on SSL port 465 with authentication. It also listen on port 25 and 587 for non-SSL SMTP.
Port 587 and 143 for SMTP (respectively IMAP) both work, but not 465 nor 993. When I set any of the later (+ check the "Use SSL" option) it hangs for one or two minutes then give a "timeout" error.
bobleponge
Postby Dean » Tue May 12, 2015 9:22 am
The problem may consist in the long response timeout from the server. Unfortunately, Everything I can advise you is to check the validity of the mail settings in Thunderbird or Outlook.
Postby bobleponge » Tue May 12, 2015 12:02 pm
Well, no, the IMAP server answers in less than 200ms.
Any log file I can check to assert what going wrong ?
bobleponge
Return to Notification issues
