activation email not coming in
Postby whizkidwho » Mon Apr 20, 2015 11:21 pm
I seem to be having a issue with the activation and also notification emails. I have setup smtp and able to receive test emails but when i click on the resend activation unable to receive anything. I looked through the form and unable to find an answer
I'm currently running on CentOS Linux release 7.1.1503. Everything is configured properly as far as i can see.
Thanks,
Julio
whizkidwho
Re: activation email not coming in
Postby Dean » Wed Apr 22, 2015 6:31 am
Please check the port 9871 to be opened (Notification service functions through this port by default.)
If you want to change the port to another one, please:
by:
vi /var/www/onlyoffice/WebStudio/Web.config
change the string:
<endpoint address="net.tcp://localhost:9871/teamlabNotify" binding="netTcpBinding" contract="ASC.Notify.INotifyService" bindingConfiguration="notify" />
Perform this two commands:
# usermod -a -G nginx onlyoffice
# usermod -a -G postfix onlyoffice
to add the onlyoffice in these groups
And restart the notify service:
/etc/init.d/onlyofficeNotify stop
/etc/init.d/onlyofficeNotify start
Postby whizkidwho » Fri Apr 24, 2015 8:34 pm
Thank you that seem to have solved my issue. Port was not open
whizkidwho
Return to Notification issues
